Here is all the details about it, if your interested.
Quick Shifter Ignition Quick Shifter
Quick Shifter Introduction
Normally during "up shifting" you must roll off of the throttle and pull in the clutch in order to engage the next higher gear. In racing (both drag and road race), split seconds count. Rolling off the throttle, even slightly, slows your times and can be the difference between winning and losing.
The Dynojet Quick Shifter (DQS) allows full throttle, clutch less shifting. This is done by momentarily cutting the fuel and or ignition, which unloads the transmission. During this time, the rider can shift up to the next gear without rolling off the throttle or using the clutch.
The PCIIIUSB incorporates all of the Quick Shifter functionality in with the main fuel controller and is fully programmable. No cutting or splicing of your bike's wiring harness is necessary.
The amount of "kill time" is adjustable by the user via the provided software. The user can also set a minimum rpm for the system to function. This keeps the system from activating at too low of an rpm, such as low speed road riding.
Note: Certain bikes require an ignition module for Quick Shifter functionality.
3 Switches to activate Quick Shifter
Shift Rod Pressure/Tension Sensor - This universal sensor mounts in-line with the shift rod. The customer must provide the appropriate "length and thread" shift rod. This sensor is available in both "push" and "pull" styles depending on the direction the shift rod moves during an up shift. For most applications, a Shift Rod Kit is available.
Linear Travel Sensor Kit - For applications where a bike does not have a shift rod, or the Shift Rod Sensor will not fit, we offer a Linear Travel Sensor. One end of this sensor is mounted to the shift lever itself and the other to a fixed point on the chassis. This sensor is available in both "push" and "pull" style to suit all installations. A universal mounting kit is included.
Handlebar Mounted Switch - A handlebar mounted activation switch is offered for situations where a Quick Shifter sensor is not legal for a particular racing organization, impractical to fit, or not preferred by the rider. The button features gold plated contacts for durability and the least amount of electrical resistance. The CNC machined handlebar button bracket has been designed specifically to position the button for the most comfortable operation and accessibility during use. To use this type of switch, the rider must first slightly pre load the shift lever, press the handlebar mounted switch, and then complete the shifter movement.
Bundling with Power Commander
Each Dynojet Quick Shifter Kit includes instructions and software that activates your Quick Shifter through your Power Commander III USB.
Finding the Right Quick Shifter for your Bike Model
Please refer to the guide below for additional Quick Shifter information. Please be sure to read about your bike's Shift Rod Kit before buying it.
Quick Shifter Installation Guides
Item Name English German
Quick Shifter Accessory Guide Pdf | Zip Pdf | Zip
Sensor Installation Instructions Pdf | Zip Pdf | Zip
Shift Rod Installation Guide Pdf | Zip
Harley-Davidson Quick Shifters Pdf | Zip
HD Quick Shifter review by Parts Mag *New Pdf | Zip
Shift Rod Specifications
Dynojet Quick Shifter Accessory Guide
Description Part No. Picture
Shift Rod Tension Sensor (Pull Type) m6/m6 threads 4-101
Shift Rod Pressure Sensor (Push Type) m6/m6 threads 4-102
Shift Rod Tension Sensor (Pull Type) m6 - 5/16 UNF threads 4-107 -
Shift Rod Pressure Sensor (Push Type) m6 - 5/16 UNF threads 4-108 -
Linear Sensor (Pull Type) including mounting kit 4-103
Linear Sensor (Push Type) including mounting kit 4-104
Handlebar Switch 4-105
Female/Female Shift Rod A (Black Anodized Aluminum) 32104060
Male/Male Shift Rod B (Black Anodized Aluminum) 32104050
Male/Female M6 Shift Rod C (Black Anodized Aluminum) 32104030
Male/Female M8/M6 Shift Rod D (Black Anodized Aluminum)
32105030
Dealer Universal Shift Rod Kit (Rods - A, B, C, D) 4-106
HD Softail, Dyna, Touring Model,(Except Wide Glide) - Shift Rod Kit 4-109
HD V-Rod Shift Rod Kit 4-110
Please read this information before making a purchase
Power Commander Replacement Accessories
Sensor "Pull" Type Shift Rod (Tension) Sensor
Part Number: 4-101
Price: 266.47
Quantity:
Sensor "Push" Type Shift Rod (Pressure) Sensor
Part Number: 4-102
Price: $266.47
Quantity:
Shift Rod kit for HD Softail, Touring Model, Dyna Wide Glide
Part Number: 4-109
Price: $296.92
Quantity:
Linear Sensor (Pull Type) Including Mounting Kit
Part Number: 4-103
Price: 266.47
Quantity:
Part Number: 4-101
Price: $266.47
Quantity:
Sensor "Push" Type Linear (Universal) Sensor
Part Number: 4-104
Price: $266.47
Quantity:
Quick Shifter Handlebar Switch
Part Number:4-105
Price: $ 96.62
Quantity:
Dealer Universal Shift Rod Kit (Rods A, B, C, & D)
Part Number: 4-106
Price: $38.00
Quantity:
Shift Rod Tension Sensor (Pull Type) m6 - 5/16 UNF Threads
Part Number: 4-107
Price: $226.47
Quantity:
Shift Rod Tension Sensor (Push Type) m6 - 5/16 UNF Threads
Part Number: 4-108
Price: $266.47
Quantity:
Part Number: 4-107
Price: $226.47
Quantity:
Part Number: 4-109
Price: $296.92
Quantity:
Shift Rod Kit for Harley Davidson V-Rod
Part Number: 4-110
Price: $316.72
Quantity:
Shift Rod A
Part Number: 32104060
Price: $12.35
Quantity:
Shift Rod B
Part Number: 32104050
Price: $12.35
Quantity:
Male/Female m6 Shift Rod C (Black anodized Aluminum)
Part Number: 32104030
Price: $10.29
Quantity:
Shift Rod D
Part Number: 32105030
Price: $10.29
Quantity:
Ignition Quick Shifter Introduction
This is a stand alone universal Ignition Quick Shifter module.
This unit allows any vehicle with 4 cylinders or less (motorcycle, ATV, mini sprint, etc.) to have quick shifter functionality without the need for a Power Commander. It comes with "coil cap" style connectors for easy installation on most late model motorcycles. For applications that do not have this style of coil the connectors can be removed and the unit hard wired in.
User Adjustable "kill times"
The Ignition Quick Shifter incorporates a gear position input so that the "kill times" can be adjusted for each gear. "Kill time" can be set shorter in high gears, while also allowing smoother and more positive shifts in lower gears (particularly the 1-2 shift).
Additionally the unit features "intellishift." The controller automatically staggers the "kill times" to cylinder for increased smoothness during lower rpm, part throttle shifts. No computer is required for setup. Installation can be done in as little as 30 minutes. Must be used with one of the 3 DQS shifts sensors (sold separately).
Universal Ignition Quick Shifter Universal Ignition Quick Shifter
Part Number: 4-112
Price: $315.00
Quantity:
Universal Quick Shifter Installation Guides
Item Name English Italian German
Quick Shifter Installation Guide Pdf | Zip Pdf | Zip Pdf | Zip
Find Power Commander Products
Select Your Bike's Manufacturer Aprilia Arctic Cat Bernelle BMW Bombardier Ducat Harley-Davidson Honda Husqvarna Kawasaki KTM Moto Guzzi MotoMorini MV Agusta MZ Polaris Suzuki Triumph Yamaha
Select Your Bike's Model
Select Your Bike's Year
Buy Product Options
Go to Dynojet Mall
Contact a sales Rep.
Call 1-800-992-4993
Power Commander
Ignition Module
Quick Shifter
LCD Display Unit
Multifunction Hub Switch
Shift Rod Kits
Replacement Parts
32105030
Part Number: 4-101
Price: 266.47
Quantity:
Part Number: 4-102
Price: $266.47
Quantity:
Part Number: 4-109
Price: $296.92
Quantity:
Part Number: 4-103
Price: 266.47
Quantity:
Part Number: 4-101
Price: $266.47
Quantity:
Part Number: 4-104
Price: $266.47
Quantity:
Part Number:4-105
Price: $ 96.62
Quantity:
Part Number: 4-106
Price: $38.00
Quantity:
Part Number: 4-107
Price: $226.47
Quantity:
Part Number: 4-108
Price: $266.47
Quantity:
Part Number: 4-107
Price: $226.47
Quantity:
Part Number: 4-109
Price: $296.92
Quantity:
Part Number: 4-110
Price: $316.72
Quantity:
Shift Rod A
Price: $12.35
Quantity:
Shift Rod B
Price: $12.35
Quantity:
Price: $10.29
Quantity:
Shift Rod D
Price: $10.29
Quantity:
Part Number: 4-112
Price: $315.00
Quantity:
Buy Product Options
Go to Dynojet Mall
Call 1-800-992-4993
Power Commander
Ignition Module
Quick Shifter
LCD Display Unit
Shift Rod Kits
Replacement Parts
