no spark
nelsiono
british columbia
fuel pump wouldnt come on so i tried to bypass lean angle shut off switch by jumping all three wires together and now i have no spark .....any ideas do you think this could fry the ecu?
What 3 wires did you "jump"?
And when you say jump do you mean you used jumper cables attached to another vehicle?
If you look at a schematic you will see 2 other component that have some commonality with the lean angle switch. Those 2 other components are TPS (Throttle Position Sensor) and APS (Air Pressure Sensor) There is nothing I see in the schematic that says how the Lean Angle Sensor is configured wiring wise so I would be guessing at an answer.
Do you have a schematic? I have one for the 06 whick should be very close if not exactly the same...
