Do a -1 up front and +2 in the back sprocket. That'll improve your low end grunt.
sorry this does not improve the low end grunt
it is not a power modification at all
ppl get this wrong all the time
it is a GEARING CHANGE
it moves the power at any given rpm to a lower road speed not engine speed
now back to this POS mod
put the bike on a dyno before and after the mod i doubt u would have gained any power, these units just add more fuel byt tricking the intake temp sensor that it is cold ( hence denser air = more fuel can be injected )
you have dropped 6mpg which is a fair bit
most guys who put on a pc3 there mpg stays the same while power increases
how u ask? easy factory the bike is set rich
rich is safe and most guys throw a zorst and filter on the bike
leaning it up a bit if the bike was set lean from facotry and then u did the mods and it leans up more this is bad lean engines = holes in pistons
a pc3 is then tuned on a dyno with an oxy sensor to detect how much fuel is going in and then the pc3 is adjust untill the optimum ratio is made
allowing for more power somtimes more fuel is added sometimes it is taken out
