Kevin,
Thanks for the information.
Your stock FZ6 seats rider area can be reshaped internally for more rearward bias, with better support, and to distribute your weight across the entire seat rather than concentrating it on the crowned center without effecting the nose shape so you will still have freedom of movement in the twisties and enhanced position and comfort. This angle correction will help allot with the slide to the tank under braking and creates a more neutral body position overall. After modification your seat will still appear from the outside to be completely stock, If you can tell something has been done just by looking at it, I have not done my job. You can find some examples on my web sites Gallery page.
The basic modification includes reshaping to your specific dimensions for better support and to correct the angle and shape to relieve pressure points and any specific problem areas that you may have. You do have a seat that can accept the Supracor suspension included in the LD modification. This is a lightweight "honeycomb" like material that does not get hot in the sun, does not harden in cold weather, and will probably outlive the seat. It is used to form a suspension between the seat pan and reshaped seating area to provide more form fitting support, and better weight distribution for longer distance comfort. It also drastically reduces vibration in the seat, and dampens road shock without changing the seat height or effecting the shape modification. If you ride any real miles and with the FZ6 seat pan shape it really is the better choice. You can find more information about the material HERE.
The FZ6 passenger area modification is similar but on a smaller scale. It concentrates on them needing a position that keeps their weight stable, and because of them having less contact points with the bike, a position that gives them more confidence and control over their position during braking and in turns.
Pricing would be the standard minimum for a two piece seat of $50 for the actual work to the riders section, a $25 material charge for Supracor, and $15 for the passenger section when done together. Your original seat cover will be re-installed after my work is complete so must be free of damage.
A photo of you in riding position is helpful and appreciated, but not an absolute necessity. Each seat is set up specifically for the rider so any additional information you think I may need regarding your position, type of riding, any medical concerns you may have should be listed in the special instructions area on the order form. When you think you have given me too much information, just a little more should be about right.
Please feel free to ship at your convenience, all that I ask is that you drop me note when you do, with the area you are shipping from, so that I can properly set my schedule. My current turnaround is no more than 48 hours so your only real downtime will be in shipping. If you visit my web site you can find the Order Form as well as my FAQ page which contains more information regarding shipping, payment, and a bunch (probably too much) general information. Contact me any time if you have questions.
Thanks again and have a great weekend, Spencer
