Neutral light and clutch issue
[email protected]
Gilbert, AZ
My neutral light turns on when the clutch is in. Just washed it. I'm sure there's water in it. I just need a visual of what I need to take apart to clean to help it? Also I'm just want to make sure it's still okay to ride for now? It's my only transportation
:welcome:to our great family!:BLAA:
It's probably okay to ride. There is a starter cutoff relay assembly under the left plastic pod by the seat. This is the logic assembly that your kickstand, clutch lever switch and neutral safety switch go to. Bet the plug is wet. IIRC the plug has 13 wires attached. Pull the plug. Blow it dry.:)
Sent from Moto's Droid using Tapatalk 2 :mikebike:
What Cliff said but, add some Dilectric grease once its dry, it'll keep it from happening again..
And, Welcome!! :welcome:
Had this same issue today after washing my bike. Noticed the light come on every time I pulled the clutch in. I decided to take it for a short 15 minute ride to see if the problem would work itself out. Error persisted.
Came in and checked the FZ6-forum and boom found this thread. Went outside with my 4mm Allen wrench and in 5 minutes fixed the problem. I've had my FZ6 for just over a year now and this forum has been such a great resource.
Just wanted to say all you guys are awesome. Ride safe!
Glad it worked! The OP never posted back with a result. Thank you for letting us know it worked because that is very important feedback that helps others on the forum! :)
+1 on the above..
I know I posted on it too, but never applied di-lectric grease as I never had an issue. Saw that relay there many a times, but didn't know what it was.
Anyway, just blew it out, put some di-lectric grease (preventive maintainance) and saved this thread for later posting!
Thank you Cliff! :Sport:
