Mounting the Cortech tail bag
sanguines
Roseville, CA
How did you do it? I can't figure out where I should be mounting them - the plastic bungee hooks feel a little flimsy and the seat handles are too close. Where do you people who already have 'em mount em? BTW I don't have the saddlebags yet; does it change when you do get them?
Thanks!
I have CoreTech saddlebags and tailbag. If you have both, the saddlebags are attached to the bike with straps and the tailbag to the saddlebags. Its much more secure than the two bungee cords that you have to make due with using only the tailbag.
I take the forward two bungee hooks and attach them to the little triangular opening on the front end of the grab bars. Then I take the aft two bungee hooks and loop them around the aft post on the grab bar and then hook it back to the bungee cord.
I just attatched mine a couple of weeks ago. I took the forward bungee and hooked it together under the seat. The rear wouldn't fit under the seat so I ran it between the grab bar and hooked it underneath on the metal brace.
