I'm considering doing a dual headlight mod, or adding auxiliary fog lights. I've read that if lighting has too much draw then the battery will not charge properly. Does anyone know the maximum draw that can be used without impacting battery charging?
Is it wattage, amperage or something else that has the largest impact on the draw.
If it is wattage then it seems that dual headlights on high would use about 120 watts. Is that okay? Is that the maximum, or can more wattage be used? The stock low beam and two 55 watt fog/driving lights would use about 165 watts.
Thank-you,
Thank-you,
