Clovis
I've searched on the forums and I think I'll be okay but I just wanted to make sure.
I've had both of my headlights with replaced with HID. I changed the wiring to leave 1 headlight on (as stock) and the 2nd HID comes on when I flick the highbeam. Both HIDs are the same at 6000.
I recently picked up a set of Firstgear Heated Gloves (Carbonfiber).
It states they produce 15 watts of heat @ 12.8 volts per glove.
I haven't picked up the troller yet so I haven't had a chance to test them out.
I'd also like to get a firstgear heated jacket liner. It comes in two versions, 65watts and 90watts. I'd prefer to get the 90 watt version but I'm not sure if the FZ6 (2007) has enough spare power.
I know the HIDs have a lower draw then the stock halogens but I don't know by how much. If I'm not driving at night I'm just running 1 headlight. I'll throw the second one on if I ride at night.
I also have two 12v power adapters installed that I use to charge my iphone (since it's my primary GPS). I sometimes use the 2nd 12v power to charge my Scala rider Q2 headset (I have 2 so I take both).
Is there going to be enough power to run the gloves and a 90watt jacket liner without draining the battery or should I just go with the 65watt liner?
Thanks!
Clovis
Thanks!
Clovis
