pantone
peter
My 09 FZ6 had 31,000 kilometer of milage. Recently I found the clutch lever was a little loose again and the slackness is out of tolerance(10~15mm). I used to extend out the adjustment nut to regain the slackness tolerance. Seeing only several thread available for further adjustment in the nut, I made a study and found the jammed clutch lever pivot will cause the clutch lever to loose. To take care of this problem, all you need to do is take the pivot out, remove and clean the old grease and apply new grease on the pivot. No need to use the adjustment nut and your clutch will be fully engaging when the clutch lever is released.
See the picture(from left to right):
1.clutch level and adjustment nut
2.pivot removed
3.pivot and nut under the pivot
ps:
1.Do not overtighten the pivot nut, it is self-locking.
2.Take care not to break the locating spring for the adjustment nut.
2.pivot removed
ps:
