vrsbrazil
Hello, I was wondering if there is any sort of GPS that is mountable (and looks good) on a FZ6?
Cool mounting!I 2nd going with a 'regular' GPS. Way less expensive and you cen even get water proof boxes from RAM Mounts for about $70 to seal them in so they are protected from rain and the elements, yet are still usable!
I use a Garmin Nuvi 260W
Handlebar Mounted
Mirror Stalk Mounted
Nice tip, thanksZiploc baggies make a cheap "waterproof" protector if needed. Just stick it over the ordinary GPS.
OK, Lot of people use normal car GPS on your bikes, that´s great, but don´t those have a charger that is made to fit car electric lighters? How do you recharge the battery on the go?
_________________________________________________________________
There's a standard cig lighter size and a BMW style (a little smaller). Just wire either up to your bike/battery. Make sure it has an in line fuse somewhere... Using an standard cig size, I'd get something marine duty (stainless steel) so you don't have rust issues, the BMW stlye outlets are designed for bikes and are less likely to come out on their own by vibrations/etc....
I have a separate line (pig tail) direct wired to the running light wire on the left ft directional. It only has power when the ignition is on.... I also have a separate BMW style outlet wired direct to the battery for battery chargers, electric clothes, air pump, etc....
Scott
