grunt720
Hey everyone!
got a gorgeous headlight today (mt03) but have a few questions about hooking it up.
so I did plug the headlight in. it works with the high beam switch set in both plugins but on the left plugin (side marked by ductap it runs set on low beam as well. where as on the right plugin it only runs when set to high beam. ideas as to why this is? to clarify its not switching how bright it is. its just on. is it running on high or low beam? is there a way to wire it so it will do both?
Also looking at the headlight there is a second bulb above the 3 pronged one. looking at the wiring the colors seem to match that of my wiring in my harness.
can I connect them together to get the bulb to light up?
Thanks!!
Thanks!!
