Protaper48
I just installed a set of rizoma rear set:thumbup:, but I was wondering if anyone ever used a pressure switch to activate your brake light instead the conventional spring that tugs on your brake switch.
I was snooping around in a garage and Im not sure if a pressure switch would fit. See to mount this pressure switch you need to remove the banjo bolt on top of your rear master brake cylinder and you replace the banjo bolt with the pressure switch that screws right in to the master brake cylinder. This way when you hit your rear brake pedal leaver the pressure in the line rises therefore activating the switch and light comes on. But the problem I see is that the sub frame gets in a way of the pressure switch. If anybody got any ideas lets hear them:cheer:
