How to replace your head bearings
mxgolf
Motoup
Beaverton Oregon USA
FNTASTIC JOB IN THIS WRIGHT UP. We are very fortunute that you were good enough to document this as fantastic as you have. Thanks A+++++
VEGASRIDER
100K Mile Member
RENO, NEVADA USA
Well I pickup my All Balls Bearing today, got them for $29 out the door, locally. Like with some other members, it's going to be a job for a pro. But I'm going to show them this thread just in case they are not sure.
Wonder if my O-rings are the wrong size contained inside the kit too.
aaronb
huntsville
Just FYI the easier way to remove the lower race is to hammer the stem through the fork. Just until it pops through (very hard without a press, but a bottle jack with something to stabilize it will work.) Then pop the next one on. BTW DO NOT USE THE FACTORY BOTTOM SEAL...you will burn out your bearings, the seals provided work perfect; although keep the upper seal. Realize this is really REALLY hard and I dont recommend anyone doing this without prior mechanical experience...this took me a whole day and the better part of the next.
Curtis
California
aaronb, can you explain what you mean by "BTW DO NOT USE THE FACTORY BOTTOM SEAL...you will burn out your bearings..."? Also, you say the seals provided work perfect, but then you say keep the upper seal. Which upper seal are you suggesting is best - new with kit, or old factory seal?
Thanks,
Curtis
Smersh
The Pillaging Tatar
Greenwich, CT
Great post! Thank you very much!
Just ordered the kit and the manual. Let's see how quickly I realize i need to take it to the shop (this usually happens after the machine in question is taken apart) ;)
Smersh
The Pillaging Tatar
Greenwich, CT
Done. This post definitely helped me avoid a lot of problems. Btw, I removed the inner race of the lower bearing by heating it up with a torch and then picking it up on both sides with large flat screwdrivers worked like a charm, just don't overdo it.
v1jay
London, UK [Berks]
My Lower race seemed like it was welded to the bottom... In the end, i had to dremel the sucker off... [i did not have access to a torch]. Did the race just slip off after expanding/heating a little...?
This thread really really helped me, so just paying my dues... Top Man..!!
cheers, vj
Smersh
The Pillaging Tatar
Greenwich, CT
I put the under-braket (i think that's what that rig is called) on three points (fork rings and the top of the axle) and heated the lower race with a propylene torch (not even a minute, i think). Then used a large screwdriver and a hammer (very lightly) to knock the race off its place - i wouldn't say it jsut slipped off the place, but it did not need much effort. I re-used the race later for placing setting the new bearing in place, per bd43's suggestion.
tjhess74
boo-yah!
North Charleston, SC
i replaced my old bearings with the all balls set a couple weeks ago. the job only took a couple hours and was pretty straight forward.
the top bearing seal is still too small, so i reused the stock one. i also had to dremel the steering stem race, as i had no means of prying it off. i used a dremel cut-off wheel and it took about 8 minutes to get it off.
the only body work i removed what the inner fairing panels, everything else stayed in place.
Def
Abbotsford, B.C. Canada
Great thread! Replaced my steering head bearings with all balls this weekend and wouldn't have done it without this post. Thanks especially to BD43. I purchased a bearing separator for $15 and a seal driver for $45 to aid in the task. Couldn't buy a spanner anywhere so had to use a hammer and large screwdriver to cinch down the steering head adjuster nut. I wouldn't recommend this method but I've done it before and made sure all the slop was out of the front end first. Front end is much better!:thumbup: Thanks again! BTW, also changed the fork oil at the same time.
Andz
Phantom Rider
Threads like this make me feel positively negligent.
Mine is 7 and a half years old.
49,000km, give or take.
Original steering head and swingarm bearings.
Original chain and sprockets.
Clutch cable has never been lubed.
One service in the last 25,000-odd km that included oil, filters and plugs.
I start it, I ride it, it brings me home with a smile on my face.
spock
Medellín, Colombia
Mine will be 3 years old this December
55,000km, give or take.
Original steering head, wheels and swingarm bearings.
Original rear brake pads
Original clutch and throttle cables ... they have been lubed :D
Currently on its second set of plugs, soon I will be replacing them.
Oil and filter changed every 8000 / 10000 kms
In the same boat as Andz: I start it, I ride it, it brings me home with a smile on my face.
Cheers
stormrider
England
Great thread. Thanks. It all ties in with what I've found out. One question though. The pipe you used to install the lower bearing, what was the diameter? It would really help me if you could let us know.
