High beam garage door opener
I posted a blog some time back that I just tap the brake 2x and it activates the door opener, works great and it's packed all out of the way too.
Doc
I didn't want to tap into the power for the high beam or install another relay (I already use a Fuzeblock FZ1), so I bought a momentary push button switch from Radio Shack (The Source here in Canada), online part number is 2750644, drilled a 1/2" hole in the fairing under the right hand mirror boot so the button is hidden and shielded from weather, then took power from my LED pod lights (a 0.5A circuit), took my GDO apart and packed it into a weatherproof box and mounted under the removable right side fairing, soldered/heat shrunk all connections... works like a charm!
