Help with Lights
swainy
Liverpool
right so i have a trip planned to ITALY in 6 weeks ! i need better lights. was thinking about swapping bulbs. no how ever reading on site looking at HID conversion... can you help with some stupid questions
1. only looking at swapping low. will the high and low beams require 2 seperate HID kits ?
2. what is difference in HID and Bi-Xenon ?
3. any modifications needed ?
4. are they both H4 type bulbs ?
The side with the high beam is ONE bulb and it's a dual fillament bulb. That means it can operate in both low and high beam (as in the dual headlight mod). To replace that with HID you need a Bi-Xenon bulb AFAIK. A normal HID is the one to replace a bulb with only one setting (i.e. the low beam only). One is H7 and the other H4, but I could be wrong about this.
Yes, the H4 is the Bi-Xenon (or high/low hallogen) and the H7 is the other one. I think. Can anyone verify this from his/her manual?
