Liamd
I'm having a strange issue with my headlights on my 2009 FZ6 S2.
I have just replaced both of my headlight bulbs (standard connection Philips xtreme H4 & H7).
On startup the main beam is now illuminated and the dipped beam is not.
If I switch the main beam switch to the on position or press the pass button then the dipped beam illuminates and the main beam stays lit.
I have no idea how this has happened as all connections seem fine and as far as I know everything is back in the correct position.
I have tried switching the bulbs back to standard, each one individually and then both together and and all combinations produce the same problem.
I've also tried connecting the main beam connection the opposite way around and I still get the same issue.
I've called around several local dealers and service centres and none of them were able to provide any insight or any possible solution/explanation so I'm hoping you guys can do better!
Also of note, I have not done the dual headlight mod. My headlights/wiring/electrics are all standard except for replacing my sidelights with LED replacements, also done today but this was a straight swap and they are working perfectly.
