snowmannn
I just mounted a set of new steel brake lines by HEL. As with most other brake lines upgrades the front hoses go from the calipers straight to the master cylinder. Do you have any photoes or guidelines for correct routing of the new lines?
So far I'm pretty satisfied with following the route of the old lines as close as possible. The only issues are how to attach the thinner hoses at the bracket that's "inside" the front fairing and also do I have to wrap the hoses in something where they pass through the two plastic brackets on the front mudguard. I thought about wrapping them because it's possible for them to get damaged or cause damage when vibrating in the larger brackets (which used to hold the larger original hoses).
Thank you !
Thank you !
