winkle30
Anyone know where to get new head lights for the fz6. Is it possible to modify to 4 bulbs? Im wanting to have head lights like some of the limited edition sportbikes i have seen.
Hello to all , I am looking to change both headlights over to 50 Watt HID. has anybody tried the 50W? . are they that much brighter than the 35W HID. the other question is , will I need the extender piece for the H7 lamp when I switch it out. I figure it would better to been scene by a car instead of the ER
that would be my suggestion, and something that I want to do eventually. Projectors are dead sexy!!!
As far as the temp , I was refuring to the heat the bulb would produce. I dont want to melt the housing. as far as color temp goes I,m looking at 6000k. I was planning on using the lite eyes double kit where you can pick each lamp. unsure about the spacer for the low beam. http://www.lite-eyes.com/index.php?main_page=product_info&manufacturers_id=&products_id=33[/URL]
did you need a extender for the low beam?. where did you get the HID kit from?
Please, for everyones sake, if you go HID get the projector retrofit...
Read through this to get some background...
the adaptor I was talking about is on the low beam (H7) . the bulb plugs into it and then into the harness. it looks like its there for the spring clip ,so the bulb will stay put. is the HID bulb have some type of thicker base to make up for it?
could i just order 2 H7 style lamps? . I am having no luck getting thru to LITE-EYES.COM , any other place you can steer me in. much thanks
