Wow. I am so glad to see them crush that pathetic abortion of a motorcycle.
Not that I'm against small bikes for training. They have their place.
But I worked as a mechanic maintaining a fleet of Ass Blasts for a dealership. These bikes were used for Rider's Edge, and they saw it all.
So, here's what happens when a bunch of beginners get hold of this "beginner's bike."
They drop it.
They drop it on the left side, taking out the turn signal stalks, the mirror, the flyscreen and headlight brackets, and bending the footpeg bracket so that it touches the primary cover. They also bend the shift shaft, which passes through the primary cover.
To replace the shift shaft, remove the primary cover. Ever tried to get a primary cover off of a bent shift shaft? I don't recommend it if you enjoy life.
Then there are the riders who drop it on the right side.
They do the same damage to mirror, signals, footpegs, etc. But with one added bonus. See that black plastic tumor on the right side of the bike? That's the airbox. It's bolted to the carb. So what happens when a couple hundred pounds of oversized go-ped lands on that airbox? It shoves against the carb. The carb shoves against the engine. The rubber boot holding the carb to the cylinder head fractures around 270 degrees of its perimeter. And now the bike will not run until it is replaced.
And as a final insulting feature, the muffler on that POS is so close to the engine that you cannot remove the drain plug for the primary drive all the way. You can get it loose enough that it'll drain, but then it pisses a quart of oil all over the muffler. That smells real good the next time you start it up.
Eric Buell may be proud of crushing the bike, but I have to ask, why did it take him so long to figure out that the bike was total garbage?
