Jon_PDX
Issues resolved - See ----> http://www.600riders.com/forum/fz6-mods/49720-givi-plx360-v35-install-not-happy-results-2.html#post548455
[Note: Pictures are in post #8 ]
Ok, here's the deal...
I've installed a lot of Givi luggage on other bikes and never run into this situation before. Also, I realize "easy bolt-on" does not usually turn out that way. There is always some adjustment that need to be done....I accept that.
The problem this time (actually two issues) is with everything mounted up the side cases (V35's) are not parallel with the center line of the bike. The front of the cases are pointing out to the sides
If you were to look at the bike from above while standing behind it, it's obvious that the cases do not run in a straight line front to back. But bow out towards the front of the bike.
Imagine the letter "V" with the bottom of the "V" at the rear of the bike and the top facing the front of the bike.
I've triple checked everything and the only thing I can conclude is that's the way the racks were designed. It's not a lot out of alignment but it's enough that even my wife noticed it.
So..... those of you that have V35's installed on the PLX630 racks are your cases running parallel to the bike or do they do the same as described above?
Also.... when installing the rear cross brace was there a lot of tension pulling the rear together?
I have about 1/2" - 3/4" space before bolting in the rear cross brace and did not feel good about putting that much tension on the racks.
So for now I left the rear cross brace off until I figure out why the cases/racks are not fitting the way I thing they should.
Oh, I put yard (meter) stick along the racks and it's not an optical illusion.
So before I take it to someone to have the racks worked over, or go out and buy the SW Motech racks (hoping they fit correctly), I wanted to find out if anyone else has noticed the same issues. And if so, were you able to fix them (and how), or just live with it.
Thanks,
Jon...
PS: I'm one of those people that will notice things that are slightly out of alignment so it's really bothering me.
Thanks,
Jon...
