Bufnitoiu
Hello guys, i hope that i can find some answeres here for my problem.
I bought a 2006 FZ6S with 7000 km and only now after another 10000 km i noticed the ABS isn`t working.
When you start the bike the abs light turns on and then it switches of and it doesnt flash or stay on.
When i did the ABS self test it all seemed to work fine (you can feel the abs in the front break lever and on the rear brake but not so powerfull like the front). The break light is working just fine, The wire harnass is ok. BUT when running, the ABS doesn`t work. I did a stoppie and the ABS didn`t work and hit the rear break and still no ABS.
After a few of these tests the ABS seemed to work only when breaking with both breaks at the same time, front and rear.
so
1 i checked the wiring - ok
2 checked all the break fluid - ok (i still want to check again the rear break fluid to be sure there is no air in the systems)
3. self test running ok on the front, running on the back but seems not so powerfull
4. checked the wheel sensors, they are clean.
Any of you have the same problem ? Or mayne there is no problem at all and i don`t know how it works. I never had a bike with ABS before.
I have attached also a pic of the bike.
Thank you in advance for your answeres.
Lucian
so
Lucian
