IIRC the rear engine/trans mount is about level with the oil filter and behind it making it part of the lower crank case/transmission case. I wonder if it would come off while in the frame? Because its pinched between the frame that could make it serious PITA! However, the crank would stay with tension of the rods and timing chain, the input shaft for the trans and clutch would stay as they are in the upper case so maybe it could be done???
Working upside down with oil in the face might be worth the hassle of pulling the engine. . . Worth looking into I suppose?
