outasight20
i think understand what you are saying, but i also know if i put the correct oil in (as i did 1st time round) i still have the problem, so it cant be simply the oil grade thats causing me to have little or no damping
but surely heavier oil will move through the holes in the damper at a slower rate that lighter oil?
i'm confused
You are right, heavier fork oil moves through the holes in the damper at a slower rate. This means that when you hit a bump with heavier oil, the oil doesn't have time to travel through the damper rod and you feel the full brunt of the bump through the handlebars. With a lighter oil, the fork can move more freely, meaning a smoother ride over bumps at the expense of increased fork dive under heavy braking. Imagine if you had no oil in your forks. You would hit a bump and not feel the initial jolt at all, however then the fork would start bouncing up and down.
I had 10W oil in my shocks for a whlie and recently went back to 5W. I like it a lot better.
