Front Caliper Bolt
Bowkill144
Rochester, NY
Hi Folks,
I was removing my front calipers and i had a hell of a time removing the caliper mounting bolts and now i would like to replace them so my question is can I use regular metric hardware with a washer or do i have to have an OEM bolt for that application. Any input would be appreciated. I will check one local shop but they always have to order anything I need, so i will just order them myself if that is the case. If I need to get OEM do you guys have a favorite site for ordering OEM hardware?
Thanks
Gene
When you put the bolts back on apply some anti-seize or lithium grease to keep them from seizing up in the future.
Lastlaugh that was the plan, I have all new bolts and i will put some of that silver never seize on there. I will need brake pads next year for sure and i dont want to go through that again.
Thanks
