wal09c
I recently wrecked my 2007 fz6 and the front forks were bent. I then went on ebay and bought a pair of forks from an older year somewhere between 04-06 and was told that they would work on a 07, well turns out they work fine till you try and put the front brake calipers back on and the brackets for the bolts are maybe a third of an inch closer together on the new forks then they were on the old. So right now I have them on the bike with one bolt holding it on as tight as I can get it so I basically dont use my front brakes becuase of this. My question would be what suggestions would anyone have in fixing this? I can seem to find any used 2007 forks anywhere and all the shops I go to want 1000 dollars for new ones which I cant afford. Is there someway I can use used R6 forks since there are more used ones out there? and of course are there any R6 forks that would fit my front brake calipers? Could really use some help here any suggestions would be great!!
