Foggy Headlight Solution!
Lowe
Midwest
Well ...I don't have a foggy headlight but I saw this at thought if you have an older fz6 maybe it can come in handy :
[ame=http://www.youtube.com/watch?v=CKAshYmrExc&feature=player_embedded]YouTube - Remove Yellow haze on headlights with toothpaste?[/ame]
Thanks for the tip!
You can use inexpensive hand rubbing compound and then a finer polish and it works perfectly.
Lowe
Midwest
Good heads up on the cooking spray. After your research, what was the advantage of cooking spray over toothpaste?
What happens with the cooking spray is it fill in the microscopic fissures that refract the light. It's a very temporary solution and doesn't correct the problem.
When you see the plastic start to haze from oxidation it's actually little micro fissures and particles that interfere and refract the light in different directions instead of the light passing through the plastic.
When you use a polish or compound you are doing a few things. Cleaning the debri that has fractured and sits on the surface from the micro fissure as well as smoothing the micro fissures so that they don't refract the light. In essence the polish or compound has fine particles that create abrasion on a microscopic level. This smooths out the larger microscopic anomalies so there is much less refraction of light and more light traveling in straighter path. The oils used in compounds and polishes fill even smaller fissures and give a straighter, better light path.
The toothpaste has baking soda that acts as a fine abrasive similar to the polishing compound but not as efficient and with out the better oils left behind.
Erci
Howie Mandel's evil twin
Pittsford, VT
Supposedly, if the headlight is pitted, toothpaste gets in the little pits and becomes very difficult to dig out. I haven't tried this personally.
Cooking spray should technically be used only if it's meant for plastic applications, but my lights are holding up ok so far.
