ny08r6
so my gf just picked up a used streetfighter headlight with buell xb9 projectors installed. Upon noticing the lights were uncommonly dim I opened it up to find the reflector metal surrounding the h3 bulb was all black. Being as I'm broke and cannot afford new headlights, I was wondering if these were options:
1. buy some 3m reflective foil tape and coat the inside of the reflector with it, then maybe clearcoat it with high temp rattlecan clear
2. spraypaint it high temp gloss white/grey then clearcoat with high temp clear.
3. maybe powdercoat it with the chrome knockoff since I have the parts to do it and the heat should never get hot enough to remelt the powder (thats assuming the material will hold up to the 400 degree treatment)
both should come out to under $20 options, and chrome dipping isn't available in the area for cheap. Which do you think would be the best option to avoid a burning/fire in the housing and still put out a normalish amount of reflected light?
thanks guys, i'll enclose a pic of the headlights to show you what I am working with, I"ll prolly just hit the top (highbeam) with whatever you guys think is best just to test it out and be able to turn it off if I start seeing problems
^you can see how the outside is starting to burn because of the heat output due to it not being reflected as well!
