Xavias
Shenanigans.
Hey all,
I couldn't pass up the opportunity as one of our dealers is hosting a customer appreciation track day at Grattan Raceway next friday for $50!!!! (Including lunch!) I know, right?
Anyway, I have a feeling I'll be pretty hooked on track days after this and I'm okay with that... but I have questions for the first one.
First off, they sent me this checklist
(X's are either currently done, or in the process of being done now)
A couple things about it:
Should I just remove the entire front fairing area? Or just tape and remove headlight fuses/bulbs?
Going to remove mirrors
Going to change brake fluid/flush system
Brake pads are fine
Going to remove passenger pegs (yay s2!)
Tires are at like 75% so they should be good. Even though they're "Dunlop roadSmart" tires... Would these be okay for the track day? I don't really want to pay to switch to nice michelin pilot powers for one track day then have to pay to switch back... I know I'll likely need a new set anyway after the track day, but I'll likely just get another set of road smarts... thoughts?
Brand new chain/sprockets, yay!
Going to flush the radiator and use water for the coolant... just in case!
Still need to do a couple things...
But I'm also planning on Removing the center stand and kickstand (I have swingarm spool sliders and a rear stand, just need to install them) and giving it a good clean and lube.
Is there anything else you guys would suggest?
Oh, and what's one thing you wish you knew before your first track day?
Thanks!
Brake pads are fine
Thanks!
