ffjrc91065
Ex- XLH rider
O.K., wizards, here's the symptom(s)
Bike Starts and runs, but at a lower RPM than should be for "cold", then, RPM's drop slowly until it stalls. I can do this repeatedly, if I turn the key off and on again (3-4 second pump run) Any attemp to open the throttle causes imediate stalling. Fuel pump is running, don't have a presure gage, but seems to be putting out a good stream. all 4 header pipes are warm. (all firing)
Background- This is the first start attemp after the winter here. The tank was replaced, during the winter, so it sat without fuel for some time. put in a few gallons and now the symptoms described above. I started it at end of Dec. with no issues. Put battery on charger for a few hours in Feb. Batt O.K. Good Volts.
Any ideas?
Any ideas?
