gusss
After changing air filter, and spark plugs, I turned on the bike to see the difference 3 times.. everything looked perfect..
When I was about to leave, I opened the switch, and ......tic-tac....
again... tic-tac---
The starter button will make the "relay" (the one located on top of battery with two 30 amp fuses) work! but not further than that...
I charged the battery as someone said here on the forum....still not starting..
The bike will turn on if pushed! then error 12 will go away...
So I am just looking to see if there is any voltage getting to the starter, since I probably pulled any cable....
Any suggestions welcome
Thanks in advance.
again... tic-tac---
Thanks in advance.
