You guys need to open these things up! Blah
There are two ways to go about this; this sensor is screwed into the block back by thermostat. By the book, you'd remove it and dump it in ice water and then boil it while reading between the body and the terminal.
It should produce the following:
5.21–6.37 kΩ at 0°C (32°F)
0.29–0.35 kΩ at 80°C (176°F)
I would start with getting it warm to say ~150F (it doesn't matter, just so it displays a number). And then unplug the sensor, inspect it, clean it and promptly plug it back in. If the 150F value drops, it could be it simply had a bad connection. If there is no change follow option #2.
Compare bikes without tearing things apart. Well unless you want to tear it apart. In that case, drain the fluid and pull the sensor. Take it out and do the ice/boil test.
Otherwise lets get a few members to measure there "Coolant temperature sensor" (CTS) when at 150F and 200F. All we need to do is get them warm and attach the meter set to ohms to the block and this terminal.
CTS is that brass thing. Unplug the connector and measure here:
