Engine braking and aftermarket exhaust
spock
Medellín, Colombia
Hello fellow riders
One of my ridding buddies has a fz6 fazer s2 model with two bros pipes no db killers, I rode it the other day and didn't like it much, going down hill I felt a noticeable lack of engine braking, much more engine braking on my stock fz6 s2 naked.
So I am wondering if switching to an aftermarket exhaust makes the bike loose engine braking.
So your comments on the topic will be appreciated :D
ChevyFazer
Redneck MacGyver
ATL
I wouldn't think it should be that noticeable but that is just another side effect from lack of back pressure
spock
Medellín, Colombia
Maybe my feminine side showed up that day and made me so sensitive :D
Talking seriously I never thought it was going to to be that noticeable.
fazed_ya
nc
Yeah I prefer the cheaper braking system (the one mounted to the wheels) but there's a lil difference between the stock setup and aftermarket impo.
degake
Stop flashing!! G$*%£#
Belgium
Maybe you were playing with that other bike a bit more? As to listen to the aftermarket exhausts? :D
You could've been going (a bit) faster with that bike versus your own, which could lead to the impression of lesser engine braking, as you will be travelling faster than otherwise.
But, as said before: less back pressure = (little?) less engine braking :)
Grtz,
Degake
callmegandhi
IM4TH
La Crosse WI
I bought my fz with Scorpion slip on already installed, but my wife also has one and I don't notice a distinct difference between them when it comes to engine braking. The only noticeable difference is mine sounds better! :cheer:
spock
Medellín, Colombia
Grtz,
Degake
You could be right my friend, your comment makes a lot of sense since that sound is definitely addictive.
mnuttall87
Arlington
My fz6 is naked, two brothers w/ no db killers and I didn't notice a difference from the stock exhaust after the switch. Just my .02
mikw73
Atlanta, GA, US
I had the same perception that the 2bros.-equipped bike I ride for a few miles had reduced engine braking compared to my bike. But it's hard to be sure with the noise from that exhaust. Also, I think I was trying a 5W40 synthetic oil in my bike at the time, which I would guess increases engine braking at least slightly. Oil might have something to do with it. Maybe tire pressure, too?
greg
UK Luchador
Stockport, UK
i don't think it'd makemuch difference
tbh i was worried this would be another thread asking why it's making that "dreadful" popping sound when decelerating* :D
*going downhill past Gooseneck and into Mansfield at Cadwell Park is my favourite place for this
ChevyFazer
Redneck MacGyver
ATL
Well it does make some difference it's just a matter of how much, essentially jake brakes/compression brakes/ exhaust brakes or what ever you want to call them on large diesels work very similar to the way regular engine braking works, you put a less restrictive exhaust on and you will loose some of the decel that a more restrictive exhaust would provide.
Circle
Sydney, Australia
Hello fellow riders
No db's? You're the man Spock.
I'm still trying to remove them without waking the kids. When it comes to bleeding eardrums vs. sleepless kids, I'm afraid the sleep beats broken ear drums.
When I put the 2bros on I did spin it around the block without he db's killers in.
Amazing. I cried a little.
wrlomas
North America in an RV toyhauler
Ha, The difference is that the raven black is just plain faster than the red. Heh heh heh. J.K.. Riding over to Calistoga saturday, if you left now we could do the loop again. Anytime buddy, anytime at all.It would be in the name of Science!:rockon:
DeusEx
Athens
I believe that the lack of engine braking is caused due to increased idle setting.
It is common, that after an aftermarket exhaust (with db-killers removed) the bike tends to idle very rough.. Therefore most mechanics (or amateurs) increase the idle setting to a pretty high level (it's the little screw on the left side of the bike under the tank).
Increased idle results in lack of deceleration from the engine...
mikw73
Atlanta, GA, US
^^ All in the name of science!!!
Actually, my '06 feels a little looser, rougher and sloppier throttle-response-wise, so mine feels a little faster. Or at least, harder to control. ;)
I'm starting late, so I'm gonba to try to average 88 mph on the way there. Should get me to SR by Saturday am. Hope my sidecases don't cost me too much in wind resistance. :p
^ The idle adjustment makes sense. I keep meaning to raise mine to see if it helps with the fuel cut-off. Thanks for the reminder.
