GravisMaximus
Looking at my wiring diagram I went looking to find out what the 4 pin connector was i found mentioned in my other post. I can not find it in the diagram!! I also hve other wires that i suspect to be for additional lights that are not on the diagram,. There not telling us everthing.... does anyone have a diagram different then mine that shows these wires???
Looking at the ecm i noticed the yellow red wire goes to the 6 pin connector and stops (for grounding to enable co adjustment), I also noticed on the diagram (ecm)the lowest pin on the right if were looking at the same schematic has no wire going to that pin, which isn't uncommon not to use all the pins but I wonder if it is a serial data pin? Any ideas?
