DaveOTZ
Helloooooo...
OK so I checked the sticky about the charging system...
So I preface this with I commute to New York City everyday...
This happened once before...
1st time traveling in Rush Hour traffic, first time the bike got hot for an extended amount of time, very stop and go traffic coupled with a couple of stalls as I had the bike about a month... It stalls and doesn't restart, I bump start it it drives fine I drop it at the shop where it still wont start. They trickle charge overnight and check my system, they say its putting out all that it should I think 12.7... The guy told me the battery is fine but a bit old that I should replace it, I order a new one from the local shop and install it... 3 months no problems...
Today I drove my wife into midtown (very heavy traffic) then to school, I noticed the start was a little rough, so I decided to take it on the HWY (my luck some muckity muck is clogging up traffic, so I go north) I try to find a gas station Im getting low, (SIDE NOTE: when the bar started blinking It went from regular odometer to trip odometer, if thats a safety feature this bike just got cooler) I finally find a station, battery is dead get some gas bump start and the engine light comes on at every red light unless I rev over 4K... Finally get home let the bike cool just pulled the battery... and lettign it charge
Im fairly certain it will hold the charge and the bike will be fine till I get another heavy traffic day... but, here are the mods (all by previous owner)
-Speedo Healer
-Dual Headlight (I read that there is no significant draw)
-Heated Handgrips (switched by key)
-Lighter (not switched, barely used, never causes a problem)
-fender eliminator with LED lights signals
Is the Speedohealer necesary? Could it be a culprit?
Wires look solid but not pretty
I will double check the grounds...
Its an 04 FZ6
Finally, the question I dont want to ask... the bike is great on longer HWY trips (great for normal commute too) for heavy city driving... Is the FZ wrong? Am I just abusing it on the NYC streets?
THanks
Daver
-Speedo Healer
Its an 04 FZ6
THanks
Daver
