BamBam77
Old but still riding
NOW THAT"S THE set up I was dreaming of usingWhat side & size did you drill mate?
Also did you use a regular drill piece or a hole drill?
The exhaust is 9.5 inches deeps
Also it's just less than an inch wide
I've ordered a 22mm step drill bit
Also 300mm drill extension bar
Thnx
I just happened to have a 3/8" drill bit 12" long from a job I did so it cost me nothing
The one thing I would do is drill a starter hole for the bigger bit that's some really hard metal your drilling through.
O and by the way I drilled as many holes as I could get started on the right side.
With that step bit you'll really be able to waler it out :thumbup:
I just saw the masonry bit to start the hole
The only reason you read about a masonry bit was because they could get a long and wide bit.
