Jinx
So this may have a little history to it. While riding for the last couple months, every so often, it felt like my fuel hose was being clogged (I get a jerky deceleration) as if it wasn't getting the proper fuel. I added some additives to the engine to try to clean up the fuel injection since I didn't want to replace the entire fuel pump to change the filter. On top of that, there were rare occasion where the motorcycle would not want to start up (Not even turn), however, a few cycles of turning the key on and off, eventually it would crank and start right up.
Now, on my way home, I had the same incidents on the freeway and when I got back to the apartment complex, riding around in low gears, it died on me. I wasn't able to start it back up (Engine wouldn't crank). Every so often, it would crank and start, but then just die.
Interesting thing, when I try to start it and it won't crank, I'm not hearing the fuel pump engage (turn on). When it does, that's when I can crank it and start it but then it just dies a little bit afterwards. I'm wondering if there's a loose connection on the fuel pump, but how does that prevent the engine from even cranking?
My two target points to test sometime tonight are the contacts to the fuel pump and the kickstand safety switch... Any other possible insights? Thanks
