clutch cable
s0n1c
Singapore
Hi. I'm riding a fz6 2006. I just bought ard 1month ago. I found that my clutch cable is kinda loose and my clutch lever have alot of free play. Do i just need to tighten it or time to change a new one.? Thks.
Try to adjust it before you do anything. (Remember too loose is better than too tight)
My shop tech told me to keep it adjusted just loose enough so that you could stick a nickel between the handlebar housing and the end of the lever. (He said most people tend to get them too tight) If you use up all of the adjustment then you may need a new cable. Good luck.
oh icic. i think mine is really too loosen. Sometimes I clutch in and up gear. The clutch did not engage fully cause my gear to stuck halfway when i'm riding.
