Capo79
Viking spirit
So, I have found a set of clip-ons that used to be on an FZR. Got them next to free, so why not. Won't know if they will work until I try, so... They'll probably get here on Monday:thumbup:
Woodcraft make clip-ons that fit....nice bit of quality kit too...but if you are going to use clip-ons, yoiu really need to get rid ofd OEM indicator mounts, as they will foul the clip on mount bracket...
You also need to install a steering stop on the bottom triple clamp, otherwise, you will damage your fuel tank when on full lock...
Oh, and a custom billet top triple clamp, without the built in risers like the OEM FZ6 top clamp...
To get a clip-on set up to work on an FZ6 is not quite as simple as it seems...it aint just a matter of bolting the buggers on...
You end up having to do indicators, steering stop, a new top clamp (preferably), and most probably an aftermarket headlight, that gives you the clearance between the fork legs, and the cli-on clamp.
:thumbup:
I ended up using ConvertiBars. They are infinitely adjustable, they just cost a little more. If you look on Ebay you can find a set for about $250 vs. $360 from the mfg. Look for 43mm.
I liked them so much I put a set on my FZ1.
Wow, crap. With all of the "The Blackbird ones just bolt on!" posts I literally thought I could buy them, swap the bars, and be good. ****. I was under the impression that I just pushed the front down a bit to give a mounting position above the triple, bolted those suckers on, and was good to go. I mean it looks like they would fit... Thanks for ruining my night:spank:
Does it change anything? Do I still have to go through that stuff to put them on? I was going to grab the blackbird ones because I found a decent deal on a set and I was under the impression that I could just lower the front a little bit, bolt them on, swap the stuff to the new bar, and be good to go. If I have to do more surgery than that it's not really something I'm going to have time or money to do. I can get the 1100XX bars for like $100, jumping up to the ~$300 range is a little too rich for my taste.
