koolfz6
I am thinking about replacing my drive chain soon, every where i look people are talking about a 525/530/535 chains. what does this mean, and what does an 08 fz6 have.
thanks,:thumbup:
thanks,:thumbup:
From another web site...
The three digit number is "used to discribe the chain size. It is based on the 'rule of eights'. The first digit is for chain pitch. This is the distance between the pins. The second and third digits combine for roller width, with a decimal point inserted between the second and third digits."
The '08 FZ6 is very likely the same as the '07 which is, I believe, a 530 chain.
Therefore, a 530 chain by the "rule of eights" has a pitch of 5/8" (15.88mm) and a roller width of 3.0/8" (9.52mm). Someone correct me if I'm wrong.
Curious... why do you want to change the chain out?
the FZ6 comes with a 530 chain. why are you replacing it?
I was thinking of replacing it in a few months, kind of a upgrade. However, I do not know alot about the chains. So i am just gathering informations right now. I guess i should as this question....how reliable are the yamaha chains from the factory, or should i go with a racing one?
