andyfazer600
Hi folks,
I removed my front sprocket cover over the weekend to clean and found loads of grime and crap. To clean it I used nearly an entire can of degreaser but in doing so made that little part of the chain clean so I decided it was time to properly do the whole thing and lube it afterwards (as I decided to remove the Scottoiler; good idea but I really did not get on with it at all :thumbdown
So to the clean and the first thing I noticed was the mess! With my previous ride being a shaft driven Honda I was not prepared Plus it doesn't help I'm a bit of a clean freak. I persevered and got it as clean I think is possible without spending days at it. It is nowhere near as clean as the "how-to" videos on Youtube. Should I really be making it look like new after every clean?
I hosed it down and dried it as best I could but decided to leave it overnight in the garage to hopefully fully dry out before I apply lube. If I can see little specs of grime tomorrow should I further clean it?
I wish I had a shaft
