'05FZ6
Hey guys, a couple of quick questions:
-How did you setup your wiring (stock FZ6 to buell connectors)?
-Do you have only the one light on low beam or both on low beat?
-What did you do with the small bulb between the main ones?
I have the dual headlight mod so I was planning on going the right bulb and mini on low beams with both lights and no mini on for high beams. Although I would like to roll around with both lights on...any input on how bright these lights are compared to stock/if I should wire both to be on at low beams)?
Also, what can you tell me about running the wires? How loose do they need to be in order to not effect steering? Last night I thought I was all done until I tested the turning. It was so tight that I actually pulled a wire out some where and now I have all my lights working but my signals don't flash and I nothing happens when I turn the high beams on...time to pull it all apart again and start digging for the broken connection
Any help is appreciated!
