faseljd
My newly acquired 04 FZ6 has a LSL naked headlight kit on it an is continually blowing the headlight bulb. Bulb is a Sylvania 9003/HB2 55 watt. At first I thought it was the plastic ring that holds the bulb in as it was loose, thinking it was rattling around in there and the vibrations were causing the filaments to break. Wrapped the ring with some electrical tape so it seated the bulb firmly. Then out test driving at night it worked fine till I opened it up to about 9k then the low beam instantly blew. Flipped it to high beam and drove conservatively for awhile more then that blew. So I am thinking voltage regulator?, rectifier?. How do I test to determine the problem? I tried the search on here but couldn't find much. I did see something about someone saying something about running a 35watt bulb versus a 55watt bulb but not sure if this would apply to my situation. Any help/ suggestions would be greatly appreciated.
