Lightndattic
All- My FZ has developed an annoying and potentially dangerous problem. When braking at anything less than the tiniest amount, my engine will die on me.
The details-
It's started doing this is the last month or so.
It does it using either the front or rear brakes. If I have to grab brake quickly at any speed, it dies.
It idles between 700 and 800 RPM (normal idle).
It does not matter what the fuel level (I first thought it was fuel starvation when the gas sloshes forward).
It's done it when the engine is below operating temps all the way to 225 degrees F (the highest I've ever seen it).
I thought it could be the clutch not fully disengaging the engine and transmission, so I tightened up the clutch cable a little using the lever adjustment, but that hasn't helped.
I've tried different grades of fuel with no difference. I usually run 87 octane ((R=N)/2 method), but switched to 93 octane with the high temps and traffic we've been getting in DFW lately.
The first time it did this, I was about to turn left across a street with traffic coming after exiting a highway (I hadn't noticed it had died). I leaned in and went to feed throttle and let off the clutch and was almost dumped off in the middle of the intersection.
Any Ideas?
The details-
Any Ideas?
