I posted this over on SBN too, but I can use all the help I can get ...
Got the FX projectors and G35 ballasts/igniters/bulbs this weekend. I've powered everything up to verify functionality (don't look directly into the light!). Relays, sockets, and fuse holders are on their way from Parts Express, and I've got a line on some aluminum plate.
Now, a couple more questions have arisen.
1. My projectors have some extra bracket metal on either side of the rear piece. Did you just Dremel that off?
2. There's also a yellow wire coming off the back. Should that be connected to ground for any reason?
3. Can you just use a screwdriver to "pry" off the shrouds holding the lenses to the projector casing?
4. Did you somehow manage to spray paint the projectors with the high temp paint (and if so, how did you avoid any overspray to critical parts like the solenoid, shutter, and reflector?)?
5. Do you have any "rotational" adjustment freedom to adjust the projectors to ensure that the output is exactly horizontal once the aluminum is cut? It seems like the aluminum adapter sets the installation angle, no?
Thanks again for all of your help. It was really exciting to power up those lamps for the first time!
