DanG
I know the manual says don't do it, but is it just a health and safety thing to avoid blinding other users? I've heard it said that the extra heat will discolour the plastic reflector, but is this speculation or has anyone tried it?
Anyone check out these new lights by philips??
Philips Automotive Lighting: MotoVision range
:Sport:
I dont' know that I'd recommend it, but I've had no problem with my cheap e-bay 110/130W bulbs (1 in each side, both brights or dims on at same time).
I'd think you'd be constantly killing the battery with that setup. I thought we only had about 50 or 60 watts or so to spare with the standard high beam running. That setup (130 + 130) vs. stock (55 + 60) is using an extra 145 watts on high. That can't be good.
How many watts do i have from not having running lights (the ones in the stock blinkers)? I did install relays, so all my power is coming straight from the battery instead of drawing it through the rest of the electrical system. I'm sure it is working my charging system pretty good though...
