07FZ6
Ok, over the last month I have looked over all the different options for modding my headlight. There are several great options, but to be honest I am a lazy SOB, and want something more simple.
SO, Here is what I am thinking of doing, can someone smarter than me tell me why it is a bad idea?
Autozone sells a replacement three prong headlight socket for like $3.99, this plug is identical to our LEFT side plug. Why couldnt a guy simply take one of these plugs, wire it direct to the left side headlight socket wiring and plug it into a modified H4 bulb using cashcrazy's method to make it fit our right housings.
I cant find a reason it wouln't work, The right bulb would react just as the left does (both lows on at same time, when you switch to highs, both sides light up) An Identical setup as the left side re-created on the right.
Another great feature would be since I wont be touching the OEM left side wiring or socket, it could just hang out of the way, and if the time came that I had to switch back to an H7, I would just plug it back in the stock way.
HERE IS AN ILLUSTRATION OF MY IDEA
