fz6man
i just got the air filter for my 06 fz6 and wanted to know how do i install it ppl say it is a real pain to do will it be worth it
Warning:
The airbox screws are self-tapping. They are screwed in at the factory and will make their own threads.
If you remove them and put them back in, it's possible for them to cut a second set of threads, which then leaves both sets weakened.
Install the screws by first turning backwards. Put a little bit of pressure on them, and turn counterclockwise. Somewhere in the rotation, you'll feel the screw drop as it falls into the threads that already exist. Once it does that, you can safely screw it in knowing that you won't be cutting a second set of threads into the plastic.
(^^^This is from some notes I saved. I got it directly someone on this forum.)
