Hey guys, just got a electronic flasher to host my LED signals, but I can't find the stock flasher... I have a Clymer manual on the way, but untill then, does anyone know where it would be located? Thank you.
Check out this diagram from Ron Ayers.com see Item #10.
Note that I've seen similar callouts for the FZ6 and the this was not the flasher relay. The flasher relay is generally a 2 or 3 wire assembly. You might actually find it inside the front faring on the left side as I and many others have found on their bikes.
