Sandseller
Hi all,
I've been fighting an intermittent instrument cluster failure on my FZ6 S2 (RJ14, 2008, ~30,000 km) since last season and I've hit the limit of what I can diagnose myself. Hoping someone here has seen this before or knows the weak point. I am getting frustrated with this bike, having constant problems
Symptom:
- Cluster (LCD + tacho) dies randomly, mostly while riding, no fixed pattern
- No stumble/hesitation from the engine when it happens. The ECU/fuelling keep running fine
- Turn signals and neutral light keep working independently
- Sometimes it comes back after an ignition off/on cycle, sometimes only after pulling the backup fuse + waiting a bit or pulling the sub-harness and waiting before connecting again, sometimes only after a long period sitting, and once it stayed dead for the rest of a ride
- Doesn't matter if the ignition is just on or if I ride
- Last season I swapped the fuses and it worked after that so I thought it would be that, This year I had no problems until this morning (it rained yesterday, the bike sits outside)
Already checked/ruled out:
- Replaced battery (AGM), replaced air filter, cleaned fuse holder contacts - no lasting effect
- ECU ruled out (engine runs perfectly fine during the failure)
- Removed the cluster, bare PCB (out of its housing) ran fault-free for an extended period (5-10min), the fault only came back after full reassembly (housing + fairing)
- Wiggling the left front sub-harness connector partially reproduced the failure, but not reliably or at one fixed spot
- Visual inspection of the board: no bulged capacitors, no visible corrosion, solder joints on the main connector (CN1) look clean (see photos)
- checked voltages last year, seemed low so I swapped the battery this year
What I planned to do:
- check voltages again
- try to clean every connector I can get my hands on
(Other problems that may or may not be relevant:
- I am unsure if my bike runs shitty or if the FZ6 is just like that. It's hopping at low rpm, sounding like a turd too. I actually wanted to change all spark ignitors and run Techron through a full tank before the cluster problem came back)
Questions for you:
1. Has anyone seen this exact failure on an FZ6/Fazer 600 S2 cluster?
2. Any known weak points on this cluster (specific components, solder joints, connectors)?
3. Has anyone repaired this themselves, what turned out to be the cause?
Thanks for taking a look!
Photos:
Symptom:
Questions for you:
Photos:
