[email protected]
MauricioC-FZ6-S-2006
The FZ6 has 2 injections every 720 degrees. The wire of the 1 and 3 - 2 and 4 cylinder's injectors is the same. The ECU has only 2 outputs to inject fuel.
The R6 has 4 independent outputs to inject fuel on each cylinder at different time.
Some questions:
1) The differences in power between R6 and FZ6 are due to:
a. Engine compression: 12.4 (2004 R6) and 12.2 (Fz6 2006-..).
b. Firing order: because 2 cylinders are taking air at the same time, so the flow is restricted. On the R6 only 1 cylinder takes air at the same time. That means more air flow and more air mass on the cylinder to compress.
c. Fuel pressure: the fuel pressure is lower when two injectors are working than one injector working at the same time.
2) The Fz6 engine is appropiate for mid range use. Is the injection and firing order an advantage or a drawback on the power and torque curves? Is this the cause of the fall of torque between 6k and 8k RPM?
3) What's the advantage of other more complex injection systems like R1 with valves, and R6 with two injectors?
4) What's the advantage of the O2 sensor installed since 2007?
5) The exaust controlled valve has some advantage?
I think is a nice idea to talk about this topic. You can review the wiring diagramas on the service manual.
Someone know about some book about motorcycle injection systems?
Thanks
:Sport:
Some questions:
Thanks
:Sport:
